Hi everyone i introduce Multi head combination Drilling machine aluminum door
this machine producted by ZHenfei _CHINA
MODEL :ZLZ4/5/6-13 multi-head combination Drilling machine
Brand In VIETNAM :MAY LAM CUA NHOM IECO
Main feature:
it is used for drilling holes of aluminum and curtain -wall profile ,as well as drilling assembly holes of aluminum and pvc window and door
adopt programmable controller (PLC ) ensure the machine running steady and reliable
the drilling head can be use individually ,combinatively or jointly as well as be combined at will
the section of profile is not more than 250X250 the processing length is up to 5000mm
the speed of saw infeed is linerity adjiustable by gas lignid damper
Technical Parameter
Power:4X1,5KW
Votage:380 VX50HZ
SPEED :1400 RPM
the hole diameter :13mm
max processing profilesection section size 250X250 mm
Distance betwween two drill hole 300-5000mm
Drilling head feeding travel 125mm
Dimention 6000X1000X1900mm
alumium cutting machine IECO VIETNAM
