Newbie catalogue Grinder surface machine
Results 1 to 1 of 1
Thread: catalogue Grinder surface machine
    Jul 2017
    Viet Nam
    Default catalogue Grinder surface machine
    Hi everyone i share document about Grinder surface machine of my company ,our name is Máy sản xuất cửa nhôm
    some technical this machine
    GENERAL FEATURES
    1.Column:
    Enlarged, honeycomb-ribbed column especially suitable for heavy duty grinding.
    2.Construction:
    Construction of table, saddle and base is casted with high grade iron, strongly ribbed.
    3.Spindle:
    Enlarged spindle set is supported by four preloaded precision angular contact Ball bearings for heavy duty.
    4.Slideways:
    Vertical, cross (double vess) and longitudinal (one vee &one flat) slideways are coated with Turcite-B, provides stable movement and durable accuracy.
    5.Automatic Continuous Lubrication System:
    All slideways and screws are fully oiled by automatic continuous lubrication system to eliminate wears on slideways & screws.
    6.Cross Feed:
    Ball screw for cross travel, powered by AC motor.
    7.Hydraulic Table:
    Table speed ranges 5-25m/min. With rack and pinion table drive for hand operation.
    8.Proximity Switch:
    Provide built-in-type (hidden) proximity switch, features safe and easy operation.
    9.Table Speed Control:
    Presettable hydraulic table speed control allows operator to pre-set speed rate, enable to get same speed rate when engaging hydraulic table every time.
    10.Hand Wheels:
    Zero-setting slip-ring with vernier on vertical handwheel, and vernier on crossfeed handwheel.
    pls see more attachment file
    Attached Thumbnails Attached Thumbnails catalogue Grinder surface machine-tieu-chuan-jpg   catalogue Grinder surface machine-ginder-surface-machine-pdf
    alumium cutting machine IECO VIETNAM
