Mazatrol EIA-Dash (IMAC-LT) and IMAC-TP service manual
Results 1 to 10 of 10
Thread: Mazatrol EIA-Dash (IMAC-LT) and IMAC-TP service manual
    Aug 2014
    Default Mazatrol EIA-Dash (IMAC-LT) and IMAC-TP service manual
    Mazatrol EIA-Dash (IMAC-LT) and IMAC-TP service manual, which is used in the QuickTurn 200C lathe, among other machines.
    It refers to the 05-mainboard, 05-servo amplifier board, MSVA, MSVB servo amplifier board series.
    For anyone who needs this information.
    Regards
    Attached Thumbnails Attached Thumbnails Mazatrol EIA-Dash (IMAC-LT) and IMAC-TP service manual-mazatrol-eia-dash-imac-lt-imac-tp
    Oct 2008
    Default Re: Mazatrol EIA-Dash (IMAC-LT) and IMAC-TP service manual
    I have a Mazak QT6 with gantry. Turns out it runs on "Mazatrol EIA Dash" I'm new to this, how do I program this machine? Is there a CAM program to feed it into the serial port on the machine?
    Mazatrol EIA-Dash (IMAC-LT) and IMAC-TP service manual-20170527_115122_1495912502237_resized-jpg
    Mazatrol EIA-Dash (IMAC-LT) and IMAC-TP service manual-20170526_105918_1495821642956_resized-jpg
    Mazatrol EIA-Dash (IMAC-LT) and IMAC-TP service manual-20170527_115155_1495912505351_resized-jpg
    Mazatrol EIA-Dash (IMAC-LT) and IMAC-TP service manual-20170526_105856_1495821645330_resized-jpg
    Oct 2008
    Thanks IEC79! In my hunt for EIA Dash I stumbled over the service manual. I finally figured it is G-Code with some Mazak quirkiness. I am hopeing that HSMX can post process my SolidWorks file. On another forum they said EIA Dash was a Mazak low spec controller? Seems no one had seen it as a stand alone on a QT-6. I am hoping I can figure how to control the GL-6 gantry also.
    Oct 2008
    From my research it looks like virtually all MAZAK QT-6G(Gang Tooling) were EIA-Dash Controlls
    Apr 2006
    Viet Nam
    Could you share me the parameter file? thank you very much.
    OMG! This manual just saved my butt! I know this is a really old post, but I wonder if you have the programming /NC operating manual for this controller too?
  7. #7
    Dec 2012
    The Netherlands
    Hey ashes-man,
    Here you find manuals for the most common brands:
    Mazak Manuals User Guides - CNC Manual
  8. #8
    Quote Originally Posted by Heavy_Metal View Post
    Hey ashes-man,
    Damn, how did I not know about that after all the googling I have done!!! Thanks. Unfortunately there are no manuals that reference this controller. All are newer or the Mitsubishi based ones. I will put a question up and see if someone has one now that I finally know what the controller is!
  9. #9
    Member Cardillo's Avatar
    Jan 2020
    Buonasera,avrei gentilmente bisogno dei parametri di un tornio qt6g.
    Grazie anticipatamente
  10. #10
    Member Ennovation's Avatar
    Oct 2022
    Quote Originally Posted by Cardillo View Post
    Bonjour
    Avez vous les listes d'alarmes de ce mazatrol
