- Problem- Spindle problem.
Spindle problem.
Hello, we have a Kasuga milling machine, Model: R-7, w/ Dynapath Delta 20-ME cnc control, Fanuc spindle servo unit # A06B-6044-H007. We don't have any manuals for this machine, except the Dynapath operator manual.
The machine works in, that we can move the slides, reference the machine, and MDI slide moves. But, the spindle will not work. When try to run spindle, by MDI,, will move very slow, in one direction, regardless of Mxx, code, also the reference voltage to the drive is besides not being right value ex: s500 shows .700vdc, s2000 2.6vdc,always positive, does not change to negative. Any advise on this would be greatly appreciated,thanks.
Re: Spindle problem.
hello
check the spindle gearbox
- You may not post replies
- You may not edit your posts
Forum Rules
