- Need Help!- Mitsubishi Meldas M0
I have a vertical machining center MCV 550E with Meldas M0.When i power on machine on the screen is in diagnostic menu EMERGENCY A and MEMORY PARITY.
Can anybody tell me how i get in to see machine parameter (axes and other) because i see only some parameter.Also i need pinout for rs232 conection (pc to meldas)
I dont have instruction(manual instruction how can i upload a parameter).
Re: Mitsubishi Meldas M0
Im getting exact same alarms on same machine did you ever find a solution?
- You may not post replies
- You may not edit your posts
Forum Rules
