- Need Help!- Daewoo ACE V35.OMC Spindle drawings
Hello guys. One of my guys removed the spindle fingers and all the disk springs (compression washers) came out from drawbar and was dopped all around. Unfortunately our drawings are no good because is showing 122 washers but our drawbar has room just for aproximately 106 washers but I am not sure what would be the real number . Does anybody has the spindle print for Daewoo ACE V 35.OMC AV 350398. If somebody could tell me how many mm should be the space on draw bar to fit all the washers it would be fully apreciated.
Re: Daewoo ACE V35.OMC Spindle drawings
Hello Everyone,
We have a Daewoo ACE-V35 OMC with through-the-spindle coolant and we need to replace the spindle drive belt. We've removed the spindle drive motor and are trying to determine how best to thread a replacement drive belt onto the spindle. Any suggestions, lessons learned from experience, etc
- You may not post replies
- You may not edit your posts
Forum Rules
