Results 1 to 2 of 2
Thread: Delta 20 Problems, not holding memory
    Dec 2009
    Have a Lagunmatic Mill with a Delta 20 controller. If it sits for a couple of hours then everything in memory clears including the settings and zeros. I can feed code via RS232 and the machine runs but if i leave and come back the controller loses its settings. does anyone have any experience with this problem and/or know how to fix it? Thanks, Max
    the pics is close to the same machine, it has the same controller....
    http://www.machinesused.com/photos/1552.jpg
    Apr 2008
    Have you checked your battery lately?I found mine in the back of the machine.
    Had to unplug everything to be able to take the cover off to get to it.
  1. Help with Delta 20 won't hold memory
    By maxoverclock in forum Knee Vertical Mills
    Last Post: 12-16-2009, 05:42 PM
  2. virtual memory problems
    By mike hide in forum SheetCam
    Last Post: 04-29-2008, 02:19 PM
  3. Fanuc OT memory problems
    By alikatcraig in forum Fanuc
    Last Post: 10-17-2007, 08:49 PM
  4. Delta Dynapath 10 problems
    By geohot in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 09-05-2007, 10:55 PM
  5. Memory problems fanuc 3tc
    By R.thayer in forum Fanuc
    Last Post: 01-29-2007, 10:27 AM
