take new parameter list and try it
Hi, I have got a problem. My machine serial communication was not working so I opened the control and removed its card and install the two comunication ICs.
The parameters were rest so I gave the parameters again but after that I have a problem. If i am working with feed rate more than 2000 machine gives gross position error or if it is at the end of table it will over travel. Please guide me where the problem may be and what is the solution
Thanks for reply can you send me parameter list and can you tell me that it is due to perameters I have attached the file containing parametrs I have used
