Does your 3000 Y axis normally home to the left?? Mine homes to the right.
Either with power off or with the machine in E-stop, manually push the Y axis some distance away form the homing point, and try again, maybe. Home the machine.....shift key (up arrow) then home (green button with 0's at the corners of each axis), should home all axes.
LinkBack URL
About LinkBacks
