If it is a rigid coupling, the best method is to bore it in one setup on the lathe. Whether a rigid coupling is best is questionable: the concentricity and perpendicularity of the two shafts needs to have zero deviation, because bearing preloading and possible shaft fatigueing will occur after running for a while.
LinkBack URL
About LinkBacks
