I have two machines and only one computer so bought a data switch box made by Belkin Components model F1b028-E it has 4 db-25 female plugs on the back and the two wires coming from the machines had a db-9 connector on the end of each one and I already cut the end and now I need to know the configeration for a db-25 at the pc end and a db-25 at the fadal end so I can wire a db-25 connector on the end.I am also hooking up a fanuc control to the box as well will I be able to use the same config on the wiring? and if not what is the config on the pinout for the fanuc? I know this may sound like a lot of work but if I can do this I will save time in the long run setting machines up . Does any one have the pinout configeration for these two machine types ?
LinkBack URL
About LinkBacks
