Results 1 to 5 of 5
Thread: Fanuc 10M will not let program download.
    Nov 2007
    I bought a use Takisawa MAC2 with 10M Fanuc control.
    Tried to download a program, no alarms. It will punch out to the PC.
    i have checked the cable and parameters and still no download.
    Is it possible to get a aftermarket port to upload programs even if something wrong with the punch board??
    Dec 2007
    Mexico
    I have a fanuc 10T, and I read programs this way...
    I hope this helps
    first I go to the PROGRAM, then READ, then there is a PROG# and here you write down the number you want your program to be, basically the same you do have after your O, and then you press EXECUTE. After that you go to your computer and send your program.
    Make sure you have all the pins in your cable right and also the terminal parameters.
    Good luck
    jlankenau
    Quote Originally Posted by rchunter94 View Post
    Registered dcoupar's Avatar
    Mar 2003
    What software are you using to communicate? Is it configured to "wait" for the CNC?
    Have you tried sending the same program you just downloaded to the PC back to the machine?
    Do you have % signs at the top and bottom of the program?
    Does LSK blink when you try to read?
    Oct 2006
    mexico
    Post same machine ,same control
    itīs there message right after the larm came up.
    it has to be (bge 807) go to paramerer and chaged to com 2 or in your pc set up com 2 instead of com 1 and That should work.
    Nov 2007
    Jose,
    can you send the parameters that are loaded for these numbers that relate to rs232c.
    20
    21
    22
    23
    5010
    5011
    5012
    5013
    etc.
    Thanks, PC only has COM port 1.
    1. PMC Ladder Upload/Download - Fanuc Powermate D
      By RLMTS in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 11-19-2011, 11:00 AM
    2. Need Help!- fanuc 0l download problems
      By edgegauthier in forum Fanuc
      Last Post: 02-10-2008, 05:27 PM
    3. CAMback easy - One Program for ALL Machines!!! [free DOWNLOAD available NOW!]
      By CAMback in forum Product and Manufacturer Announcements
      Last Post: 11-06-2007, 09:29 AM
    4. FANUC 6TB Unspecified Alarm on Download
      By smithy2167 in forum Fanuc
      Last Post: 08-14-2007, 10:14 PM
    5. Fanuc 18i Comms Download & Upload
      By Mr_Carpyman in forum Fanuc
      Last Post: 06-26-2006, 02:14 PM
