Results 1 to 7 of 7
Thread: dynapath delta 20
    Feb 2008
    Egypt
    dynapath delta 20
    HELLO EVERY BODY .
    I BOUGHT TREE MILL MACHINE HAVE DYNAPATH CONTROL DELTA20 MODEL 1990 AND I DO NOT KNOW WHAT CAD /CAM PROGRAM I CAN USE WITH IT BECAUSE I HAVE TRIED SO MANY PROGRAMS BUT IT LOOKS THAT I MISS SOME THING
    IF THERE IS ANY BODY CAN HELP ME OUT .
    THANKS ALL AND BEST REGARDS
    dre
    dre is offline
    Apr 2008
    united states
    im in the same situation, i have a delta 20 vmc and bob cad will not communicate with it, there is no post for it. if you find out anything please let me know also
    May 2010
    You can get a manual from Dynapath.....they're 200 bucks, though. It will have all of the information about what the control is looking for.
    The code needed is nothing really out of the ordinary. I can tell you that you must not have spaces anywhere in your code.
    Any CAM system with a configurable Postprocessor should work fine.
    You must also have a program name as your first line. It must be in parenthesis, all capital letters. Like this..... (TEST).
    Those are some of the most common snags.
    May 2010
    BobCAD/CAM lists many Dynapath 20 posts for free on their site, BTW.
    dre
    dre is offline
    Apr 2008
    united states
    michaelthomas
    thank you for the imfo , ive been trying forever to communicate with this dynapath. all i want to do is save programs
    Feb 2009
    Early dynapaths do not have Eia programming, so you need a dynapath post. Later deltas have the Eia function, the basic of which would be a fanuc om I believe. You do have to modify the post for the end of block, beginning of the program, fixture /tool offset commands. Also, I have run in to some dynapaths that were wired for parallel communication, rather than serial, this is simply switching lines 2 and 3.
    dre
    dre is offline
    Apr 2008
    united states
    thanks, i figured that there is a trick somehow. i have version 18 bobcad and they want give me any support anymore to communicating with this control
    1. DNC w/Dynapath Delta 20
      By rr167 in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 07-01-2011, 08:46 AM
    2. dynapath delta 20
      By chipman in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 12-15-2008, 02:47 PM
    3. delta dynapath
      By camtd in forum Deckel, Maho, Aciera, Abene Mills
      Last Post: 01-13-2008, 12:45 AM
    4. dynapath delta 10 help
      By undertowx in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 07-05-2006, 10:49 AM
    5. Dnc dripfeed for Dynapath Delta 10
      By badgs750 in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 05-21-2006, 02:37 AM
