Results 1 to 2 of 2
Thread: sheken
    Nov 2007
    sheken
    I am new here ! Having trouble with connecting up new PC. Not sure what Printer port I should be using. Maybe it is the wrong Port. I am not getting power to X Y Z. Just a tiny squeak! Checked power connections etc.
    Using Licensed Mac3 V48. Some advice would be appreciated.
    Thanks, Sheken.
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    Greetings and welcome aboard!
    Have you double checked your setup/configure for MACH? You can (at least MACH2) choose which LPT port you are using - Guess you could try re setting the configs. There are also a couple of good port finder/ringers you could look for (google) to make sure your port is active.
    Best of luck Jim
    might try this one - at least its free:
    http://www.sofotex.com/Parallel-Port...ad_L25940.html
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
