Results 1 to 5 of 5
Thread: X-axis moves position while running
    Aug 2007
    Question X-axis moves position while running
    This just started happining while I'm running programs the X-axis moves on its own. I tried sepperating the cables and ran another program it still did it. Im running mach3. I would very much appriciate it if someone could help.
    Mar 2007
    Seperated how far. Should use shielded cables.
    Oct 2008
    1)Check X-axis brake
    2)Check parameters
    Oct 2008
    Registered Khalid's Avatar
    Apr 2006
    Pakistan
    i THINK ANY OF YOUR WIRING IS LOOSE..CHECK ALL THE CONNECTIONS...
    1. No A axis moves ? ( in post )
      By Scott_M in forum FeatureCAM CAD/CAM
      Last Post: 08-09-2007, 09:37 AM
    2. Converting G2 & G3 Moves to Rotary Axis?
      By skibbey in forum G-Code Programing
      Last Post: 04-03-2007, 08:40 AM
    3. Z Axis Running Away
      By sandefuj in forum Industrial Hobbies (Support forum)
      Last Post: 02-23-2007, 07:36 PM
    4. Z Axis Home Position Problems
      By JMFabrications in forum General Metal Working Machines
      Last Post: 10-24-2006, 11:58 PM
    5. Z position moves up during run
      By henryj1951 in forum Gecko Drives
      Last Post: 03-27-2006, 06:16 PM
