Results 1 to 3 of 3
Thread: Fanuc ac spindle drive alarm 01
    Aug 2007
    india
    Red face Fanuc ac spindle drive alarm 01
    Dear all
    We have one turning center having fanuc OT controller it shows message 2001 spindle fault,then i checked drive it shows alarm 01 - motor over heat so please help me how to solve this problem.
    regards,
    suresh
    Dec 2003
    If the motor or machine in general is not overheated, it may be one of the Thermal sensors faulty, there is often one built into the motor, two leads coming out which should have zero resistance, occasionlly one in the spindle supply transformer is used, it is buried in the winding.
    Aug 2007
    india
    thanks Albert E
    as per ur guidence i checked motor pulse coder and thermal sensor wire i found one wire RB from pulse coder disconnected after connecting it m/c working ok
    thanks once again
    regards,
    suresh
  1. Fanuc spindle alarm AL-12
    By kadettevo in forum Fanuc
    Last Post: 02-17-2013, 04:44 PM
  2. Replies: 2
    Last Post: 07-19-2007, 02:17 PM
  3. Alarm 123 Spindle Drive Fault
    By Shotout in forum Haas Mills
    Last Post: 05-27-2007, 12:48 PM
  4. Spindle drive alarm in fanuc 16 ta
    By miguisu in forum Fanuc
    Last Post: 02-20-2007, 11:12 AM
  5. Spindle Drive Alarm AL-03??
    By msmart in forum Fanuc
    Last Post: 11-25-2006, 11:27 PM
