Results 1 to 4 of 4
Thread: CNC initialization problem
    Jun 2007
    Slovenia
    Unhappy CNC initialization problem
    Need help at JONES & SHIPMAN CNC SURFACE GRINDER FORMAT 5/200.
    I kindly request help in guiding us to sort out the below mentioned problem.
    We change the battery cause the one we get it in the control was totaly Empty.
    When the machine is powered on the following messages are shown on the screen:
    SERIES 8600 ver 1.0U
    DISC???? COMM???
    BUBBLE???? CPL???
    CMOS????
    EPROM????
    ***INIT ABORTED***
    Many Thanks in advance,
    Peter
    Jan 2007
    Hamilton,Oh
    What make/model is the machine? What make/model is the control of the machine?
    Had you experienced this problem before you changed the battery? Was the machine turned on or off when you changed the battery?
    Of all the parameter backups you've stored for each of your CNC controls inhouse, find the one for this particular machine and print a hardcopy (if not already) and compare to the ones in the control. If not able, are there any other screens you can pull up, such as a "Setting" screen?
    Jun 2007
    Slovenia
    Well it's 2001 model, with Allen Bradley 8600 control.
    Power was absolutely off during the battery change. The mashine was working well, like it should.
    The only thing i'm able to get on the monitor screen is by pressing the P01 buttun which displays the following message:
    "FILMS1 20 PRESS RETURN TO START JCL"
    After pressing ENTER:
    "JOB"
    And thats it.
    Regarding the CNC control parameters... don't know exactly what you mean, sorry.
    Dec 2003
    Unfortunatly, without the parameters is is just a big chunk of iron.
    The batteries should always be changed with the power on.
    The only hope you have is to get a copy of the parameters from whoever fitted the AB control, either J&S or who ever retrofitted it, if after market.
    This is all the data that configures the machine.
    This can include, in some cases the PLC/PMC data which controls the machine external functions.
    Plus you will need the reload procedure.
  1. What's my Problem?
    By barnon in forum DIY CNC Router Table Machines
    Last Post: 06-05-2007, 11:28 AM
  2. problem
    By kiethnt in forum General CAM Discussion
    Last Post: 03-27-2007, 03:32 PM
  3. VF0 problem
    By Brendan in forum Haas Mills
    Last Post: 01-16-2007, 12:42 AM
  4. Cad problem
    By Kevin Moore in forum OpenSource Software
    Last Post: 11-24-2006, 04:30 PM
  5. PM problem
    By ger21 in forum Forum Questions or Problems
    Last Post: 08-14-2004, 11:26 AM
