Results 1 to 5 of 5
Thread: Help, Artisan IFB Card 37 Pin to LP 25 Pin Adapter
    Feb 2006
    I am looking to see if anyone has made an adapter cable for sale, that takes the 37 pinout from an IFB Card (Artisan software interface card) to a standard 25 pinout. I need this interface cable so that I can use a Griffin Controller directly to an LPT port on a PC, thus for use with Mach3 software.
    Artisan software typically uses the IFB card interface plugged on a spare port of the PC mother board. I am trying to do without it, and go directly from controller to the PC using the more modern Mach3 control software. The thing is that the Griffin controller is wired for a 37 pin connector to match the IFB card, it has separate aux and Limit SW Sub-D connectors that branch from the 37Pin connector, so I just need the interface 37 to 25 pin cable since all the pinoputs stem from the 37pin connector.
    I can make one but it would save me the hassle if someone already has one for sale at a reasonable price.
    Thanks IA
    Feb 2006
    Ok, I looked at options and found some breakout boards, might be an option or simply install a 25 Pin male connector on the existing control box and rewire the 4 IMS Drives directly to the 25 connector? I don't think I need optoisolation because I think the IMS drives in the Grifin Control box, already have it inside them. But I have yet to verify this with IMS specs..looking some more... Any suggestions comments, options would be appreciated?
    Feb 2006
    no comments or suggestion? so far...
    Apr 2007
    UK
    Feb 2006
    PR ,I cannot acces that group until I sing in and they approve me. So would it be posible for you to copy and paste that info here in this thread? Thanks
    1. 1/4 to 1/8 collet adapter?
      By CRFultz in forum DIY CNC Router Table Machines
      Last Post: 04-17-2010, 02:54 AM
    2. need help with lathe adapter
      By Lionclaw in forum General Metalwork Discussion
      Last Post: 01-03-2007, 08:02 AM
    3. 56c motor adapter for IH
      By Runner4404spd in forum Industrial Hobbies (Support forum)
      Last Post: 10-28-2006, 12:02 PM
    4. 3/8 to 1/2 adapter
      By TMaster in forum Benchtop Machines
      Last Post: 07-29-2006, 07:15 AM
    5. Adapter for ballscrew
      By ahren in forum DIY CNC Router Table Machines
      Last Post: 03-23-2006, 06:51 PM
