Haven't seen the other thread so I apologize if some of this has already been covered.
1) Can you send in the opposite direction (CNC ---> PC)?
2) Did you ring out the cable or does it work on other machines?
3) Can you try another PC with same cable using HyperTerminal or another utility?
4) Can you try same PC with same cable using HyperTerminal or another utility?
LinkBack URL
About LinkBacks
