Results 1 to 5 of 5
Thread: need help getting eia files from mazak m32
    Jan 2007
    I have mazacam, CNCPC and I downloaded pc-dnc and I get any of them to pull these eia programs. Now using the same cable I can get mazatrol programs. But these eia programs there is always a misconnect issue or com port problem. Does anyone have any ideas or suggestions? The guy who used to do this left, so they are making me do it and I am not that well versed in these software packages or serial communication. I also have the microdisk box, could i do it with that?
    Jan 2007
    I have had the most luck with PC-DNC, it transmits--but then it says it cannot read the data
    Feb 2007
    i know you have to use the tape button instead of the cmt button. i don't know if that helps.
    Jan 2007
    yes, I do know about the tape button. Thats how I am doing it. I have gotten that far, but with pc-dnc it transfers and then says the data is unreadable. I know the program is OK because they are running it. Thanks for the input.
    Feb 2007
    i am actually argueing with a mazak blue box right now trying to get info from some t2 disks into griffo brothers. keep fightin the good fight.
    1. DXF Files
      By deanrach in forum General Metalwork Discussion
      Last Post: 11-25-2006, 01:09 PM
    2. ncp files to dxf or dwg
      By greenmanor in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 10-26-2005, 11:33 PM
    3. What files
      By CNCadmin in forum Mach Software (ArtSoft software)
      Last Post: 07-08-2005, 05:27 AM
    4. DXF or PLT files
      By signIT in forum DIY CNC Router Table Machines
      Last Post: 07-01-2004, 05:57 PM
    5. 3D dxf files
      By NeoMiller in forum General CAM Discussion
      Last Post: 11-06-2003, 10:42 AM
