Need help to set home on an Excel-810
I have an Excel-810 (smaller version of the Excel-1300) vertical machining center that needs it's Z home position and tool change position reset. This machine has a Fanuc 0M control.
I'm familiar with setting the zero position of a machine, but do not have the procedure for setting it on this machine. Even just the numbers for where the first and second zero points should be relative to the table should work.
I know the paramaters I need to set:
510 Z Grid shift amount for each axis. (Machine home position)
710 Z Coordinates of the referance position for automatic coordinate system setting. (should be left at zero)
737 Z Distance from the first referance position to the second referance position. (tool change position from home)
Any help would really be apreciated.
Thank you
Dale
edit: clarification and correction of paramaters.
