Results 1 to 3 of 3
Thread: Error when trying to run NCLink on Windows 7
    Oct 2004
    I installed NClink on Windows 7 to use it for drip feeding but I get an error.
    The same installer installs perfectly fine on XP machines but even though it installs on W7 the program doesn't work on a Windows 7 machine.
    When NCLink starts it goes through the ad screens just fine but when it gets to the last one and you click it to start the NCLink program it displays a "Failed to create empty document" error and quits.
    I tried changing the ONCLinkF2k.exe file compatibility to run on XP SP3 mode and I also made it run as administrator. I made TMP and TEMP folders in C in case it was trying to write to a temp folder that didn't exist.
    I have run out of ideas to try to make it run on Windows 7. Anyone has any idea why this is happening?
    Thanks,
    Jeff.
    Dec 2010
    Has anyone found a solution to this problem? I just downloaded this program to try it out on a Mag-Fadal 4020 and I get the same error message.
    Jul 2009
    Finland
    Doesn't work on 64-bit OS.
  1. Yasnac MX3 DNC with NCLink?
    By wyobmf in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 05-19-2010, 05:29 AM
  2. Need Help!- Matsuura Mc500v seq error/magazine error
    By mc500v in forum General Metal Working Machines
    Last Post: 01-08-2010, 02:35 PM
  3. Need Help!- Error 414 Z axis error detect- servo alarm
    By andywids in forum Fanuc
    Last Post: 07-09-2009, 11:33 AM
  4. Need Help!- Error 414 Z-axis error detect servo alarm
    By andywids in forum General Metal Working Machines
    Last Post: 07-09-2009, 10:56 AM
  5. Windows XP or Windows 2000 better with Mach2
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2004, 11:08 AM
