Results 1 to 6 of 6
Thread: General Question
    Moderator CNCRob's Avatar
    Feb 2005
    General Question
    At work I use an old RYE CNC machine. We have a cnc office where we have 2 computers to draw parts and generate the g-code. Each cnc machine is connected to both computers in the office so we can doanload the programs straight to the machines. The way the machines are setup we can see the folder that all the programs are in because they designated that folder when they setup the machine. I was wondering is there any way to see the files on the cnc machine itself from the computers in the cnc office? The control software on the machine is Osai and the computers in the office are using XP Pro. I have no particular reason to firgure this out but I has just been one of those curiosity questions on my mind. If you have any answers please let me know. Thanks- Robbie
    Dec 2003
    I personally have not seen any machine that will let you read the directory, a PC based CNC may be able to do something like this, but I doubt an older CNC would.
    The closest thing I have seen for older machines etc, is almost a reverse procedure, a program like Cadem allows the CNC operator to remotely request a file from a distant, unattended computer and upload and download to it. This will work with almost every CNC that has a RS232 port.
    Mar 2003
    Utah
    Al is right. The machine control has to be on the network with the office computer, usually not through the rs232 cable, but through an ethernet cable. Most new machines should be able to do this, ie: Mazak, Haas, Milltronics, etc.
    Feb 2005
    Hey Al and Mortek, Thanks for your quick answers. Is there any way just to see the machines are there from the office computer. We also have a new Onsurd that was just bought about 8 months ago. Its running Windows 2000 pro under the control software, is there any way to see it from the office. Thanks again- Robbie
    Dec 2003
    I am not familiar with the Onsrud, but if it is PC Win2000 based then you should be able to use any of the normal communication/network sytems available, this is usually one of the reasons for a PC based CNC control. Obviously you should have all the manuals for the machine and I would have thought there would be a section on running other s/w.
    Mar 2003
    Utah
    You should be able to buy a network card for the control running windows 2000 then connect that to the office computer through an ethernet cable. Then allow file sharing on the machine computer. Then the office computer could see your machine and the machine could also be set up to see files on the office computer. Then you could transfer files by dragging them to the control's file.
    1. Extremely basic machining question.
      By touser in forum General Metalwork Discussion
      Last Post: 06-19-2005, 01:51 AM
    2. Question about power supplies
      By dowling177 in forum General Electronics Discussion
      Last Post: 01-28-2005, 08:01 AM
    3. Hobbycnc controler question
      By chas in forum Hobbycnc (Products)
      Last Post: 09-09-2004, 06:00 PM
    4. Just a question about plunge milling.
      By Machine1 in forum Hard and High Speed Machining
      Last Post: 01-28-2004, 09:36 PM
    5. HF lathe question
      By rs1300 in forum General Metal Working Machines
      Last Post: 01-19-2004, 12:22 PM
