Do you get any alarms when this occurs?
How long is the cable?
Is the cable shielded, and is the shield connected to pin 1 on the NC side?
What is the standard baud rate for the Matsuura 560v and where do you change it? I don’t know if it the distance from computer to machine or the baud rate. Short programs are ok but longer ones send to machine fine but from machine to computer I am losing info or it puts last part of program in one continues line.
What model Yasnac do you have?
No alarms.
We have it set up on a network from computer to each com port at each machine so thoes cables are quite long and shielded. from com port to machine is very short but still using a 25ft cable.
The controler is a Yasnac MX3 version 08062.05 - 08954.03
I had the same trouble with my 2 CHNC's at same distance till I lowered the baud rate.
This question you asked I do not know the answer to.
"Is the shield connected to pin 1 on the NC side"
How do you tell?
Try putting in line delay and check FIFO on comm port on the pc. If you still need help, give me a call directly.
Greg Mercurio -Shop Floor Automations
www.shopfloorautomations.com /619-461-4000
