Results 1 to 4 of 4
Thread: serial transfer work only one-way
    Jan 2006
    Romania
    Hello all,
    I have a strange problem with a Mazak L-32 laser cutting machine.
    I succeded to transfer files form the machine to the PC using the RS232 serial port, but I could not transfer files form the PC to the machine.
    Does anybody run into the same problem ?
    Radu
    Jul 2004
    Do you receive an alarm at the machine or nothing at all when sending from the PC to the Mazak?
    If alarm, then you know data is getting to the Mazak but probably timing, format or parameters. If nothing, then you might have a problem at the PC or cable.
    What are your current communication parameters on the PC and CNC?
    What software are you using?
    Greg Mercurio -Shop Floor Automations
    www.shopfloorautomations.com /619-461-4000
    Jan 2006
    Romania
    Hello Greg,
    First of all, thanks for your interest in helping me.
    I receive nothing when trying to transfer programs from the PC to the machine. Everything looks dead.
    I do not believe that either the cable or the transfer parametres have any problems, because the other way (machine to PC) works perfect.
    I have adjusted the parameters until I got a transfer without any loss of data (program data).
    On my opinion, I suspect that Mazak requires some non-visible characters to be inserted at the begining and/or at the end of the program (spaces, tabs, enters or something elese, or some combination of these).
    If the machine does not find these characters, the transfer won't work.
    As software solutions I used both NC-net lite and Easy DNC.
    Perhaps I have to use a Mazak-agreed solution, but I have no idea which one.
    Thanks again for the help,
    Radu
    Jul 2004
    Try send the program that came out of the machine back to the machine. If you get an alarm,then check cable or port on the pc. You can also get rs232 tester to verify data is going to the machine. See our website for a sample.
  1. zl 200 transfer
    By SmokinErb in forum Mori lathes
    Last Post: 07-09-2009, 05:30 PM
  2. transfer of program
    By Dar in forum Bridgeport and Hardinge Mills
    Last Post: 09-13-2007, 10:43 PM
  3. Free DNC RS232 software for serial file transfer
    By bborb in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 08-04-2007, 07:28 PM
  4. how to transfer?
    By hop in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 06-15-2006, 12:35 AM
