What make and control type?
I recently bought a second hand lightly used cnc plasma cutter.
I have found it to have erratic line drawing behaviour and this morning while operating a dry run the machine went booloo.
I switched off power and restarted only to find that 'card1' was not found by the software.
the drives are compax3
I am very tempted to start from scratch with the computer, as although it was built in 2007 it is running win95 and looks quite old.
I am an amateur who is really keen to learn..
Any suggestions?
Iain
Hi Al,
it's a custom build from these people
http://www.plasma-profiling.com/acatalog/shop.html
this the actual machine.
not sure what you mean by 'control type?
ah yes, the software is called 'GNC'
I have been advised tht I may be better off using something like 'Mach3'
would that just tke oer the running of the machine?
Depends what type of drives you have, if analogue not step/dir then you would need to replace the drives.
