Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 02-21-2010, 06:49 PM
Karsue is on a distinguished road
Mazak H15 / 4th Axis Alarm
Hi there,
I have a problem on Mazak H15 with 4th Axis with Alarm 259 PS DRIVE MALF. (Index T).
The termal relay is normally close and there is no problem with relay or heat, even the next day by turning on the machine after referencing all the axis (X,Y,Z) by start to turn 4th axis the alarm appears.
Has any one face the same problem or has experience with this alarm???
Please advise me to remedy the problem.
Thank you.
Karsue
[IMG] code is Off
Need Help!- Mazak alarm Bala Mazak, Mitsubishi, Mazatrol 4 01-21-2011 04:48 AM
MAZAK ALARM 404 CHANDRU Mazak, Mitsubishi, Mazatrol 4 12-21-2009 08:41 AM
Need Help!- Mazak M2, 448 alarm? Wimbleball CNC Machining Centers 0 10-23-2009 04:46 AM
Need Help!- alarm on mazak chipsahoy Mazak, Mitsubishi, Mazatrol 4 09-08-2009 09:01 PM
Problem- Mazak SQT 18 205 alarm twistedturner General Metal Working Machines 0 03-08-2009 04:06 PM
