| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
I have a Mori MH40 Horizantal Machining Center with a Fanuc 6M controller . For years we have used a laptop and a cable to the RS232 port to load and save programs . Recently our laptop was stolen (along with the program we used ) and I'm trying to get something working again . I downloaded a free DNC program from Cadem but I was wondering this . Can I still use the same cable we always used or will it have to be rewired for this software ? Also how do I go about finding out things like the stop bits and parity . I have a manual for the 6M but haven't found it in there yet . I have found a little info online about the 6M settings but they give a baud rate of 2400 and I know I've always used 1200 in the past .Any help with this would be greatly appreciated . Thanks in advance ..Doug |
| The same cable will work. If your new laptop has a serial port, you're lucky. If not, you can get a USB to Serial adapter, but a better choice might be to get a PCMCIA Serial Adapter. http://www.siig.com/ViewProduct.aspx?pn=JJ-PCM012-S3 The 6M parameter settings can be found here: http://www.aggsoft.com/cnc-dnc/fanuc-6m.htm |
| Yep your right It's a 15 pin connector not a 9 pin . Thanks again . |
Yeah..that 15pin Female is the external monitor port. If you dont have the DB9 MALE pin, then you will need to add the serial port as Dave mentioned. Use a PCMICA or Xpresscard or USB. We have options for the laptops on our website if you need further help.
__________________ Greg Mercurio -Shop Floor Automations www.shopfloorautomations.com /619-461-4000 |
OK since my last post I have been able to obtain a disc containing the old PCDNC program we have always used along with the programs that were in the directory the last time we loaded it into a laptop . I bought a USB to Serial Port adapter , loaded the drivers for it, and tried it out at work today . So basicaly I'm using a proven program , and cable , same settings I have always used in the past the only things different than I have always used is the laptop and the serial port adapter . First I tried Machine to Laptop . Program transferred beautifully . Then I tried the other direction . Not so great . About 6 lines of the program loaded and then I got a RS232C Alarm . Looking it up in the fanuc manual it seems to indicate a data overflow problem . I went to the properties af the serial port and found some adjustments for FIFO buffers . I tried slowly adjusting the buffer for transmitting until I had it bottomed out . It DID load a little more of the program but still gave me the same alarm . Is there some other way to slow down the data flow ? Any help would be greatly appreciated . |
#11
| Fanuc procedure is to use XON/XOFF for data flow, if the CNC sends a XOFF and the PC sends more than 100 characters you get an overflow. Al.
#12
| OK Al and dcoupar . I'll try these things out Monday ..LOL I somehow thought that using this program we used before was going to save me a ton of trouble . Maybe not . I tried it again today and had totally different results. I couldn't get a program from the machine to the Laptop and at first couldn't get 1 the other way either till I hit the F1 key on my laptop , then it sent part of it to the machine and gave me the same RS232C alarm as yesterday . Don't have a clue why it suddenly quit working from Mach / Laptop I'm thinking I'll just uninstall everything this weekend start from scratch and try the things you guys have suggested. Thanks for the replies . Doug |
| Need Help!- DeskCnc and my laptop | greasetattoo | Carken Products (Deskam, DeskCNC etc) | 4 | 02-24-2010 11:09 AM |
| Need Help!- ver 23 and laptop | Claude Boudreau | BobCad-Cam | 8 | 10-09-2009 07:50 PM |
| Laptop vs PC for CNC | Helikiwi | Benchtop Machines | 20 | 09-12-2009 10:11 AM |
| Can I use a laptop? | rweatherly | General CAM Discussion | 4 | 07-05-2005 12:02 PM |
| PC vs. Laptop | DAB_Design | Computers and Networking | 10 | 07-26-2004 08:04 AM |
