| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
Does anybody know anything about programming the PLC on a Fanuc 0M? My shop has a Lucas boring mill that we can't program an M04 because of a bug in the PLC program. We install CNC's all the time and know how to program the PLC's in other controls, but know nothing about this Fanuc. I do have a hard copy of the ladder, which is how I figured out where the problem was. I also was able to read the PLC program out of the eproms, but it's in binary and I have no way of dechipering the code back into a readable program. Does Fanuc have PLC programming software still available for this control? If so, how much $$$ does it cost? Any help appreciated, Scott |
| What is the nature of the problem? does the M3 work ok? As you probabally already know the M4 usually just output the spindle reverse signal and the FIN signal will wait until the up-to-speed, before the program will continue, it is usually very little ladder. The Fanuc software and programmer cost a bundle unless you can rent of off someone. If it's an original bug, what about recourse back to the machine tool builder to correct it? Is the Fanuc set to display the ladder on the screen, with bit status? Al
| Al, Yes, the M03 works OK, but because of a bug in the ladder, the FIN signal never turns on when the M04 is commanded. The spindle actually starts in reverse, but the programs hangs because the CNC is still waiting for the FIN signal from the PLC. Can you tell me how to display the ladder on-screen? In my explorations so far, I haven't come across this. Scott |
| Thats odd, the M4 is usually identical to the M3 except that it outputs the reverse signal instead of forward, and waits for the same FIN input which is the spindle-up-to speed, which is the same for both M3 & M4. Is this a ladder problem or that for some reason the up-to-speed is not occuring in the rev direction, The input status screen for this signal should confirm this. I will have to look up the parameter to allow display of the ladder. Al
| The software is only available from Fanuc, also depends on what format the PLC is in eeprom board etc, also AFAIK you still need their programming terminal, I do not have the above but fortunately I have access to it, a large local corporation purchased it when I retrofitted their machines and they allow me to go in an use it anytime. Fanuc should be able to let you know what you need. That is one reason why I like companies like Mitsubishi, the software is free (or used to be) and any old PC can be used, you can also program right on the screen. Al
| Thanks Al, We have the PLC manual coming from Fanuc. Hopefully this will help. I still think we are going to have to find someone who can do this for us, but you never know. I agree with you on the Mitsubishi, I think their controls have the best built in PLC's of anybody. Scott |
| There is always a set of keys that have to be pressed when dealing with fanuc.. On my machines it is the pgdn key 2x's with the machine in manual mode or someting along that line (maybe shift and pgdn key). It's been a while since I have done any plc programs on it, but I am familiar with many other plc programs if it is a routine you need help developing?
__________________ menomana |
| You need the FAPT programming software for your PC, this is available for big bucks from FANUC. It sounds like you already have an EPROM reader and burner so you are good there. Also, Fanuc calls it PMC (Programmable Machine Controller) not PLC there is a difference in the way the ladder is scanned. The control scans in priority; High, Med, and low. Be carefull not to change things in the wrong priority levels and not in another as you can cause a bit to be set high and low at the same time causing problems with the machine. Not all Fanuc 0-series controls had dynamic ladder display. Older models A & B did not support the display of the ladder. Newer versions Model C & D allow the user to view the ladder for troubleshooting. Fanuc 21, 16, 18, & series 15 controls now allow the ladder to be modified in the control and it is far better than Mitsubishi has ever been. |
#10
| Thanks to all! This control turns out to be a Fanuc 0M-A, which does not have the on screen ladder display. We have a tech from Fanuc coming out on Monday to work on it. I'll be watching over his shoulder every chance I get though .Thanks again, Scott |
#11
Scott, Did this ever get resolved? Would you mind telling what Fanuc charged to come out & do it? I read your post today (4/29). We could have had you email the bin file, we could decompile, edit, burn a new chip and send it to you. Especially if you knew what needed to be changed. Regards Paul Sevin Ovation Engineering, Inc. http://www.ovationengineering.com off. 586-336-1590 cell 586-764-1125 fax 586-336-1589
__________________ Paul Sevin - Ovation Engineering, Inc. http://www.ovationengineering.com |
#12
| Paul, Now you tell me. I didn't see the bill, but it was a guy from GE Fanuc in the Detroit area. I do know that they bill round trip travel plus they have a four hour minimum charge. But he was able to make the change we wanted, so I guess it all worked out. If I had known you could work from the eprom files, that would have saved us a lot of time and money. You could have just emailed the files back to us, we have an eprom programmer. Oh well, now we know.Thanks, Scott |
| Fanuc 3M DNC operation | max_c | General Metal Working Machines | 3 | 07-04-2010 07:11 PM |
| Blueprint Programming fanuc 18T | adamant | G-Code Programing | 7 | 09-12-2005 12:22 AM |
| Fanuc motor ??? | jevs | Servo Motors and Drives | 3 | 03-16-2005 04:47 PM |
| Fanuc 21-GA_416 Alarm-Axis Disconnect | lasermike | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 03-10-2005 12:49 AM |
| FANUC coding compatability?? | m1911bldr | TurboCNC | 3 | 04-24-2004 05:10 PM |
