Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 02-01-2010, 10:50 AM
alib is on a distinguished road
Error sending code to a Heidenhain 151b via Serial
Please accept my apologies for my first post being a question and that it could also be in the wrong section! However I'm doing this as a favour for a friend who isn't technically minded.
He's got a Heidenhein TNC 151B control. We've managed to get files from the TNC using a serial - parallel cable and TNCserver. However we have a couple of problems:
1) TNCremoNT fails to connect to the TNC, am I right in a assuming that this is because the control is too old to support GUI file browsing?
2) We've managed to take small programs off and put them back on to the machine, using TNCserver and the 'read-in offered program' option within the control. However we can't get the following program back on to the machine (it came off fine). We receive a 'wrong program data' error on the control screen. What are we doing wrong? The code ran fine when it was on the machine! Within the user options the machine lists 1418 blocks free (I am assuming this is memory)
If I attempt to backplot the code in NCplot I get an 'Invalid Character' error. But after much fiddling I can't find anything that looks incorrect.
The only other thought I have, is that I've read posts regarding 'trickling' programs to a control. Is this something we need to be investigating / using for this control?
Thanks for any suggestions or help!
Code of the dodgy program is below:
Code:
0 BEGIN PGM 5 MM
1 TOOL DEF 1 L+0,000 R+10,000
2 TOOL DEF 2 L-18,900 R+5,940
3 TOOL DEF 3 L-30,130 R+6,650
4 TOOL DEF 4 L-23,650 R+4,000
5 TOOL DEF 5 L-13,100 R+3,000
6 LBL 1
7 CYCL DEF 7.0 DATUM SHIFT
8 CYCL DEF 7.1 X+0,000
9 CYCL DEF 7.2 Y+0,000
10 TOOL CALL 0 Z S 1500,000
11 L Z+6,000 R0 F9999 M05
12 L X+125,000 Y+50,000 R0 F9999 M
13 LBL 0
14 STOP M25
15 TOOL CALL 1 Z S 1500,000
16 L X+0,000 Y+0,000 R0 F9999 M03
17 L Z+2,000 R0 F9999 M08
18 L Z+1,000 R0 F400 M
19 LBL 2
20 CYCL DEF 5.0 CIRCULAR POCKET
21 CYCL DEF 5.1 SET UP-1,000
22 CYCL DEF 5.2 DEPTH -6,000
23 CYCL DEF 5.3 PECKG -3,000 F350
24 CYCL DEF 5.4 RADIUS11,500
25 CYCL DEF 5.5 F350 DR-
26 CYCL CALL M
27 L Z+0,000 R0 F500 M
28 L Y+20,000 R0 F500 M
29 CC X+0,000 Y+0,000
30 C X+0,000 Y+20,000 DR- R0 F500 M
31 L Y+29,000 R0 F500 M
32 CC X+0,000 Y+0,000
33 C X+0,000 Y+29,000 DR- R0 F500 M
34 L Z+1,000 R0 F500 M
35 L Y+49,000 R0 F500 M
36 L Z-5,500 R0 F500 M
37 L Y+44,250 R0 F500 M
38 CC X+0,000 Y+0,000
39 C X+0,000 Y+44,250 DR- R0 F500 M
40 L Y+49,000 R0 F500 M
41 L Z-11,000 R0 F500 M
42 L Y+44,250 R0 F500 M
43 CC X+0,000 Y+0,000
44 C X+0,000 Y+44,250 DR- R0 F500 M
45 L Y+49,000 R0 F500 M
46 L Z-16,500 R0 F500 M
47 L Y+44,250 R0 F500 M
48 CC X+0,000 Y+0,000
49 C X+0,000 Y+44,250 DR- R0 F500 M
50 L Y+49,000 R0 F500 M
51 L Z-22,000 R0 F500 M
52 L Y+44,250 R0 F500 M
53 CC X+0,000 Y+0,000
54 C X+0,000 Y+44,250 DR- R0 F500 M
55 L Y+49,000 R0 F500 M
56 L Z-26,650 R0 F500 M
57 L Y+44,350 R0 F500 M
58 CC X+0,000 Y+0,000
59 C X+0,000 Y+44,350 DR- R0 F500 M
60 L Y+49,000 R0 F500 M
61 L Z+2,000 R0 F9999 M
62 LBL 0
63 LBL 8
64 CYCL DEF 7.0 DATUM SHIFT
65 CYCL DEF 7.1 X+250,055
66 CYCL DEF 7.2 Y-0,060
67 LBL 0
68 L X+0,000 Y+0,000 R0 F9999 M
69 L Z+2,000 R0 F9999 M
70 CALL LBL 2 REP
71 CALL LBL 1 REP
72 STOP M25
73 TOOL CALL 2 Z S 1500,000
74 L X+0,000 Y+0,000 R0 F9999 M03
75 L Z+1,000 R0 F9999 M08
76 LBL 3
77 CYCL DEF 5.0 CIRCULAR POCKET
78 CYCL DEF 5.1 SET UP-1,000
79 CYCL DEF 5.2 DEPTH -6,050
80 CYCL DEF 5.3 PECKG -6,050 F500
81 CYCL DEF 5.4 RADIUS11,560
82 CYCL DEF 5.5 F400 DR-
83 CYCL CALL M
84 L Y+37,350 R0 F9999 M
85 L Z-2,500 R0 F150 M
86 CC X+0,000 Y+0,000
87 C X+0,000 Y+37,350 DR- R0 F450 M
88 L Y+38,000 R0 F500 M
89 L Z+2,000 R0 F9999 M
90 LBL 0
91 CALL LBL 8 REP
92 L X+0,000 Y+0,000 R0 F9999 M
93 L Z+1,000 R0 F9999 M
94 CALL LBL 3 REP
95 CALL LBL 1 REP
96 STOP M25
97 TOOL CALL 3 Z S 1500,000
98 L X+0,000 Y+0,000 R0 F9999 M03
99 L Z+1,000 R0 F9999 M08
100 CYCL DEF 5.0 CIRCULAR POCKET
101 CYCL DEF 5.1 SET UP-1,000
102 CYCL DEF 5.2 DEPTH -6,030
103 CYCL DEF 5.3 PECKG -4,300 F300
104 CYCL DEF 5.4 RADIUS12,500
105 CYCL DEF 5.5 F450 DR-
106 CYCL CALL M
107 CALL LBL 8 REP
108 L X+0,000 Y+0,000 R0 F9999 M
109 CYCL CALL M
110 CALL LBL 1 REP
111 STOP M25
112 TOOL CALL 4 Z S 1500,000
113 LBL 4
114 L X+0,000 Y+7,320 R0 F9999 M03
115 L Z+1,000 R0 F9999 M08
116 L Z-8,000 R0 F500 M
117 CC X+0,000 Y+0,000
118 C X+0,000 Y+7,320 DR- R0 F800 M
119 L Z-1,100 R0 F9999 M
120 L Y+10,650 R0 F500 M
121 CC X+0,000 Y+0,000
122 C X+0,000 Y+10,650 DR- R0 F800 M
123 L Z+1,000 R0 F9999 M
124 L Y+32,350 R0 F9999 M
125 L Z-1,200 R0 F800 M
126 CC X+0,000 Y+0,000
127 C X+0,000 Y+32,350 DR- R0 F800 M
128 L Z+1,000 R0 F9999 M
129 L X+0,000 Y+0,000 R0 F9999 M
130 CC X+0,000 Y+0,000
131 LP PR+20,500 PA+90,000 R0 F9999 M
132 CYCL DEF 1.0 PECKING
133 CYCL DEF 1.1 SET UP-1,000
134 CYCL DEF 1.2 DEPTH -3,400
135 CYCL DEF 1.3 PECKG -3,400
136 CYCL DEF 1.4 DWELL 0,000
137 CYCL DEF 1.5 F250
138 CYCL CALL M
139 LP PR+20,500 IPA+45,000 R0 F9999 M
140 CYCL CALL M
141 LP PR+20,500 IPA+45,000 R0 F9999 M
142 CYCL CALL M
143 LP PR+20,500 IPA+45,000 R0 F9999 M
144 CYCL CALL M
145 LP PR+20,500 IPA+45,000 R0 F9999 M
146 CYCL CALL M
147 LP PR+20,500 IPA+45,000 R0 F9999 M
148 CYCL CALL M
149 LP PR+20,500 IPA+45,000 R0 F9999 M
150 CYCL CALL M
151 LP PR+20,500 IPA+45,000 R0 F9999 M
152 CYCL CALL M
153 LBL 0
154 CALL LBL 8 REP
155 CALL LBL 4 REP
156 CALL LBL 1 REP
157 STOP M25
158 TOOL CALL 5 Z S 1500,000
159 LBL 5
160 L X+0,000 Y+0,000 R0 F9999 M03
161 L Z+1,000 R0 F9999 M08
162 CC X+0,000 Y+0,000
163 LP PR+20,500 PA+90,000 R0 F9999 M
164 CYCL DEF 1.0 PECKING
165 CYCL DEF 1.1 SET UP-1,000
166 CYCL DEF 1.2 DEPTH -22,000
167 CYCL DEF 1.3 PECKG -4,000
168 CYCL DEF 1.4 DWELL 0,000
169 CYCL DEF 1.5 F100
170 CYCL CALL M
171 LP PR+20,500 IPA+45,000 R0 F9999 M
172 CYCL CALL M
173 LP PR+20,500 IPA+45,000 R0 F9999 M
174 CYCL CALL M
175 LP PR+20,500 IPA+45,000 R0 F9999 M
176 CYCL CALL M
177 LP PR+20,500 IPA+45,000 R0 F9999 M
178 CYCL CALL M
179 LP PR+20,500 IPA+45,000 R0 F9999 M
180 CYCL CALL M
181 LP PR+20,500 IPA+45,000 R0 F9999 M
182 CYCL CALL M
183 LP PR+20,500 IPA+45,000 R0 F9999 M
184 CYCL CALL M
185 LBL 0
186 CALL LBL 8 REP
187 CALL LBL 5 REP
188 CALL LBL 1 REP
189 STOP M25
190 STOP M02
191 END PGM 5 MM
[IMG] code is Off
Need Help!- 18i-T = 368 B AXIS: Serial data error (int) padobranac Fanuc 6 03-16-2009 06:04 AM
Sending a program Fanuc 18-m parity error Tom Zegers Fanuc 7 01-20-2009 06:36 AM
Heidenhain 151B featurecam post processor maybe4x Bridgeport and Hardinge Mills 0 06-20-2008 06:06 PM
Heidenhain Tnc 150b, 151a, Or 151b Control Gute General Metalwork Discussion 2 09-17-2007 08:07 AM
Sending code to the Fadal CNC errors? HCG General CNC (Mill and Lathe) Control Software (NC) 2 11-11-2005 01:02 PM
