Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 01-06-2010, 09:40 AM
gjp gjp is offline
gjp is on a distinguished road
X/Y/Z/A not responding, Spindle does respond
My company owns a CNC which has a 4-axis setup (X/A, Y, Z) and contains a Rockcliff Motor 4 Axis Driver Board (RCF00108). It has been working very well for us until right before Christmas, when it went down.
Our computer uses the Mach3 software to control the CNC. Currently the spindle works, but everything else does not. When I use the manual controls on Mach3 (Left-Right for X/A, Up-Down for Y, PageUp-PageDown for Z, F5 for spindle), everything is unresponsive except for the spindle.
I was wondering if any more experienced CNC users/problem solvers on this board had any ideas on how to revive our CNC again.
I am in contact with Rockcliff. So far, they have asked whether or not the green light on the board is on. I definitely do not see a light on when I look at the board. However, I do not see an unlit light bulb anywhere either. I am not sure if our board has a green light or not. I am certain that there are users out there who are also using a CNC with this board. Please let me know if there is a light and where on the board is it located?
Thank you for your time and attention.
[IMG] code is Off
Need Help!- Tornado 200 Fanuc ot not responding spindle and turret tkea Fanuc 10 05-21-2012 12:29 PM
Need Help!- Cambam not responding joshuadri CamBam 5 06-22-2009 02:54 PM
Plastic material defined causes computer to slow way down and stop responding tirebiter Solidworks 2 02-08-2008 04:08 PM
Edgecam not responding fantasy2 General CAM Discussion 2 10-29-2005 02:16 AM
SL10 Lathe NOT RESPONDING on POWER UP ! mannster Haas Lathes 12 06-22-2005 11:08 PM
