| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
| Do you have a USB port? If so a USB to RS232 converter usually works, cost around $25.00 Al
Caboose Howdy!,thought I was only person to use a meldas series control, glad someone else has heard of it.I also am having trouble,have several leeds out,maybe will find something,will post results. GOOD LUCK Bear |
The M50 is a fairly recent control, I have used this model in quite alot of retrofits. Al
| Hi Al so have you been able to set up some kind of I/O port confg.? Caboose didnt mention if he is using a cadcam program or not, I have been trying to set up bobcam sys. but no luck,so far. Am trying to confg a meldas 50/G 50/L to M5 turning center to save programs as this has very little memory. Bear |
| Are you looking for a program for download and the parameters and cable info? or any of the above? Here is a start including most of the info you need as well as a free download program. http://www.cadem.com/ncnet/freednc.htm Al
#10
| USB to serial adapters are problematic. We have been working in the RS232 communication area for over 10 yrs now and with new laptops, a standard DB9 connector is no longer common. Most have an USB port and PCMCIA slot on the side of the laptop. Tested the $9.99 Ebays, Frys special - upto the B&B, Blackbox ($175) and other serial expert hardware makers /suppliers of USB to serial adapters with random acts of problems (great collection of these things now ) Today a customer used a COMPUSA - I Conquest USB to serial adapter for $29 and sent to the CNC, it started to then randomly start over in the middle of the part program. He used MasterCAM and then shareware DNC and same issue with both. Purchased a PCMCIA card from us and worked like a champ. If any one has a recommended unit that works reliability every time, for drip feeding and loading to the memory of controls, please share. I have found that most vendors of the USB to serial adapters wrote the drivers for Win98 or NT, then ported them into Win2000 and XP and the hardware is not the same. The operating system and drivers do not work and the buffers seemed to be flakey. Spend $150 or less and get a working solution with reliability using the PCMCIA card for laptops and serial communication to machines.
__________________ Greg Mercurio Shop Floor Automations, Inc. www.shopfloorautomations.com (619) 461-4000 Tel |
#11
| Check with Hu_flung_dung, he has just accomplished the wireless to RS232 transmission. AL.
#12
| This works for us, but, have not tried to drip feed with it. http://www.cdw.com/shop/products/def...spx?EDC=325871 |
| Okuma LC-20 Threading problem | Gunner | Machine Problems, Solutions , Wireless DNC, serial port | 13 | 12-13-2011 10:11 PM |
| RS232 problem sending with newer PC | sys_man | Computers and Networking | 15 | 06-10-2005 08:36 PM |
| RS232 failure to send in XON/XOFF, hangs WAITING, thermally caused. | gar | Haas Mills | 3 | 05-27-2005 07:44 AM |
| CNC gantry Machine shows problem | Alex S.A | Machine Problems, Solutions , Wireless DNC, serial port | 15 | 04-25-2005 03:02 PM |
| Fadal VMC4020A axis problem | cwww | Machine Problems, Solutions , Wireless DNC, serial port | 16 | 12-01-2003 11:07 PM |
