Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 01-05-2010, 09:43 AM
cncdigger is on a distinguished road
MOTOR ALARM ON MAZAK LATHE
The machine is a Mazak Slant Turn 15 Universal 1000 with a Fanuc 6T Control (year 1983)
After it's been turned on, the MOTOR Alarm Light comes on (On the controller). It can come on at start up or at any given time after start up, but usally within 15 minutes. When the MOTOR Alarm is on, the TACHO LOSS led comes on on the board in the rear cabinet.
At that time, I can still move the axes but I cannot perform a tool change. The hydraulic pump is still running.
Is it possible that it is loosing the Tacho Signal from the Hydraulic Pump? Is there such a thing?
Thank You!
Alain
[IMG] code is Off
MAZAK ALARM 404 CHANDRU Mazak, Mitsubishi, Mazatrol 4 12-21-2009 08:41 AM
Need Help!- Mazak M2, 448 alarm? Wimbleball CNC Machining Centers 0 10-23-2009 04:46 AM
Need Help!- alarm on mazak chipsahoy Mazak, Mitsubishi, Mazatrol 4 09-08-2009 09:01 PM
Problem- Mazak SQT 18 205 alarm twistedturner General Metal Working Machines 0 03-08-2009 04:06 PM
Mazak L Alarm SFA Machine Problems, Solutions , Wireless DNC, serial port 2 05-26-2005 12:52 AM
