Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 01-05-2010, 06:34 AM
Router Lady is on a distinguished road
CNC Shorting out ground problems
I have a Gerber Sabre Router 408 . I have had to replace a curcit board 5 times in one month . We have grounded it to the building but are still having shock probs. We are getting no error messages .
Any comments or help would be great
Old 01-05-2010, 11:56 AM
Al_The_Man's Avatar
You need to test the effectiveness of both your service ground and the validity of any ground conductor from your machine to the service ground.
This can be done by a qualified electrical company.
Make sure the whole machine has bonding conductors from all metalic parts of the machine back to the enclosure where the service ground should terminate.
It sounds like your machine is 'floating' above ground reference.
Old 01-06-2010, 10:33 AM
Thanks AL..I'll look in to it..
[IMG] code is Off
Need Help!- G320 Problems, No Power, Estops and Ground. Phife Gecko Drives 33 05-11-2009 08:20 PM
Frame ground vs. Electrical ground. polaraligned Granite Devices 2 11-24-2008 04:21 PM
Need Help!- To Ground or not to Ground That is the question! Mr.Chips DIY-CNC Router Table Machines 1 03-16-2008 03:10 PM
Motor supply ground vs Logic ground? Gashmore General Electronics Discussion 11 06-07-2005 05:21 PM
To Ground or Not to Ground Mr.Chips Xylotex 1 05-01-2004 11:05 PM
