Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 04-03-2005, 06:36 PM
Lu_ca is on a distinguished road
LPT crazy
hi all i've tried for a long time kcam, then i have installed the mach2 demo, then mach1 demo and still cncplayer demo...but yesterday my cnc doesn't work anymore, wich each of these program my motors make noise only boring noise and so they didn't turn. i have so tried to change pc and all work fine so i sure that is a problem of lpt. I use xp sp2 and i can't understand how solve my problem, probably one of these program is in conflict, i don't know i would like to have a solution. Many thanks in advance
Old 04-03-2005, 08:02 PM
dwwright is on a distinguished road
restore?
Have you tried restoring your OS from a previous day? XP has usually does a backup every week or during installs, so you could use the restore to get back to where you were prior to trying out Mach2.
Darren
Darren
http://www.libertystainedglass.com
Old 04-04-2005, 04:58 AM
yes, I've tried yet but it doesn't change the situation, I don't know how to do. there's a method to reinstall the lpt port with the original config?
Old 04-04-2005, 08:57 AM
My first guess would be to right click on My Computer, click Properties, then go to the hardware tab, then click on Device Manager. I'd make sure that the Mach 2 device driver is uninstalled, if not, right click on it and click Uninstall, then reboot. If that doesn't fix it, then try removing the LTP1 port under Ports and reboot and let XP reinstall it.
Darren
Darren
Old 04-04-2005, 08:59 AM
Also check your kcam config to make sure your still pointed to the right port and correct pins. Perhaps your config got changed. I have the HobbyCNC board and it seems like the default config was wrong for this board.
Darren
Darren
Old 04-04-2005, 01:45 PM
thanks for your reply, i have check all hundrend time, I have also uninstall the mach2 and also the lpt port, now i have fix the irq on 7 and now my motors turn but really slow and unregular there a problem on lpt gestion but i can't find yet.
Old 04-04-2005, 03:46 PM
Hate to say it, but it sounds like the port is fried. Usually removing the device will prompt XP to automatically find it. I don't know if booting to safe mode will find the new hardware or not, but may be worth a shot. Other than that you may want to look for an add-on Ltp card on ebay.
Darren
Darren
Old 04-04-2005, 05:54 PM
Smile
sorry, maybe i'm not clear, holding up the irq of my lpt on "7" like the same valor of my mainboard, all seems to work but not like usual, so i suppose there is another problem, the lpt work well i sure, i tried a printer and it work fine, probably i must format and reinstall winxp if i haven't any other choice. My lpt is surely not dead but it is seriously wound
Old 04-04-2005, 09:34 PM
ah, so which mode are you running on the ltp port? Standard, EPP, or EPC? Check your bios setting for it. I started mine running Standard and found EPP worked much better. Hope this helps...If not let me know and I'll keep making suggestions
Darren
Old 04-05-2005, 06:17 PM
ok now all work fine, i have delete manually del system reg of my driving stepper program, change irq of mainboard and so in xp reinstall lpt and reinstall only one of the driving program, thanks for yours help!
[IMG] code is Off
Sherline spindle to 30k RPM -- am I crazy? nicad General Metal Working Machines 21 11-17-2010 02:57 PM
Cheap Unipolar LPT Driver, High Amperes Urgundiz General Electronics Discussion 19 06-23-2009 08:45 AM
Help with LPT Stepper Interface nickleplated Stepper Motors and Drives 5 06-08-2005 07:28 PM
Aligning cross table is driving me crazy. Ideas? pigifly General Metal Working Machines 4 07-07-2004 02:45 AM
Indexer LPT - HELP! CNC Pro General CAM Discussion 3 03-11-2004 02:20 PM
