| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
Hi, I try if here is someboby who can help me with my little problem. I Have Dyna Myte 4400M and its with ATC. Now the changer is elapsed, still working but little bitt to low compare to spindle. ATC program is like below... 0 9000 ATC IF (#1034 EQ#201 GOTO7) N1 M19 N2 ZP2 T#20 N3 G28 Z0 N4 M71 N5 G30 ZP2 N6 M72 N7 G4 X.1 N8 M99 - question is, how can i change spindle position when its up to change point, now the dimension is 93.800 and i must change that about 2mm down. Does anybody know where or what is that value i have to change? Thanks! Meldas |
| - Go to the ALARM/DIAG screen and press the soft key for PLC-I/F. - At the bottom of the screen in the first three fields, enter 1001 in the DEVICE field, leave DATA empty, and M in MODE and press input. - Go to TOOL/PARAM, then press the soft key for ZP-RTN. - Press the NEXT key to get to the screen for the Z axis (3/3). Enter the new tool change position for parameter #14. This number is set in mm even if the machine is set to run in inches. When I make adjustments to the tool change position, I disconnect the air line from the machine so I can move the ATC arm with my hand. Orient the spindle and use the handwheel to move the Z axis to the tool change position and then just pull the ATC arm over to engage the tool in the spindle. Enter the new value in the parameter, shut off the control, reconnect the air supply, home the machine and try the tool changer. |
| Dyna Mechtronics 4400 (DM4400, dyna myte) reference + brochures & photos | ckm | Knee Vertical Mills | 190 | 02-18-2012 12:42 AM |
| looking for a Dyna Myte DM2400 | rcm | Want To Buy...Need help! | 3 | 05-15-2009 12:58 PM |
| Need Help!- Dyna Myte 3000H | shep640 | Mini Lathe | 3 | 10-25-2008 05:30 PM |
| Need Help!- DYNA MYTE PARTS | davidponte | Want To Buy...Need help! | 0 | 04-12-2008 07:28 PM |
| DYNA MYTE 2400 | helfriwj | Benchtop Machines | 4 | 04-01-2008 10:45 PM |
