| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
Hello I am experience a difficulty with my CNC Multicam Router. My computer is connected to the router and everything seems to be working fine, except when I go to run the job...there is no list of jobs that I've sent to my router. Usually there is. I've rebooted my computer, shut the machine down. Brought everything back up and resent the job. Still no job on the router...and fully connected to it. Do you know what could be causing this problem?? or How do I get my jobs back onto the router?? Any help will be very appreciated!!! Thanks so much |
| Is "jobserver" the multicam software that you are using? Looking for folders at your machine, like Jobs1, Jobs2 etc...? If so, right click the little butler looking guy in your taskbar, (if he isn't there, then Jobserver isn't running and it needs to and that might be your problem) click DNC on the menu that appears after right-click, and ensure that the file location directory listed in the DNC window is the one where you are sending your job files to. If not, click the button to the right of the window, and browse until you find it. Click it and then click "reset DNC" and you should be good to go. |
| Tags |
| files, multicam, problem |
| Need Help!- How can I convert .nc files into .nci files | AlphaD | Fanuc | 2 | 07-08-2009 01:45 PM |
| Need Help!- Convert files to Inventor files. | bartL | Autodesk Software (Autocad, Inventor etc) | 7 | 02-03-2009 11:38 PM |
| convert .dnc files to .plt files. | feraldave | General CAM Discussion | 1 | 10-13-2008 04:48 AM |
| SolidWorks Files For K2CNC Mount and Hitachi Router | solodex2151 | DIY-CNC Router Table Machines | 0 | 06-10-2008 06:18 PM |
| Converting Illustrator files to Gcode files | acoop101 | General Metal Working Machines | 1 | 06-05-2008 03:53 PM |
