Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 03-17-2005, 07:20 AM
Calico is on a distinguished road
Question How do you "connect" dual motor X axis ?
is there anyone ever explain in drawing in this forum ?
any website / info about this ?
rud
Old 03-17-2005, 08:07 AM
ger21's Avatar
You can use Mach2 and use the slaving option to link them in the software, or you can drive two drivers from the same step and direction pins. It's not a good idea to physically connect 2 motors together.
Old 03-17-2005, 10:51 AM
ViperTX is on a distinguished road
It not even a good idea to use 2 motors to drive the same axis. The motors, drivers are not matched and are at best loosely synchronized.
Old 03-17-2005, 11:33 AM
Question 2 motors for X axis ?
so how you deal with big Y axis arms ? that required 2 motor for X .
I see alotta big CNC using 2 X axis motors.
is there some kind of Syncronize stuff ?
rud
Old 03-17-2005, 12:12 PM
ger21's Avatar
Shopbot and many other commercial router manufacturers have been doing it for years.
Old 03-17-2005, 12:22 PM
Yes, and their stuff is not under $2K. You have to use the driver and software and feedback from the motor to synchronize the movement...it's not a trivial task. You can't just throw in a few Geckos connected to Mach2 and have a commercially viable product.
Old 03-17-2005, 01:28 PM
ger21's Avatar
Shopbots prior to the new models introduced a few months ago had no feedback. As for Mach2 with slaved Geckos, plenty of people use it just fine with no problems.
[IMG] code is Off
4020 4th axis problems little bubba Fadal 3 06-13-2005 09:08 PM
dual x axis leadscrews? bobleecnc Mechanical Calculations/Engineering Design 1 03-18-2005 03:18 PM
2 axis to 3 axis conversion drembedded Bridgeport and Hardinge Mills 10 10-27-2004 11:32 AM
Dual Screw Axis thielert DIY-CNC Router Table Machines 9 11-25-2003 10:57 AM
2.5-Axis vs 3-Axis JamesBond General Metal Working Machines 6 07-26-2003 07:09 PM
