Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 03-15-2005, 04:51 PM
Vince.P is on a distinguished road
Unhappy Parameters
I have A Dawoo puma 8s with a fanuc controller OT and a 12 turret tool holder lathe. THe problem is getting a rom 998 parity alarm and now getting servo varity alarm. From what i here it's the memory board. but the thing i need is if any one has a boot disk for the parameters or program sheets on the model. Cause at the time i can not get into the ladder part of the program to set the machine speeds and servo timers.
any help would bo great
Old 03-15-2005, 08:11 PM
Al_The_Man's Avatar
Some fanucs have a bit to set to enable display of the ladder, Machine speeds and servo settings are not usually done in the PLC (ladder), except for the feed overide switches etc.
Al
Old 03-18-2005, 08:27 PM
well i was talking to fanuc and they told me to reset all parameters and start over starting with the 900's the start with the normal parameters ie:001 002 so on and so on, tryed many different way but still can't get to the 6000's it bypasses it complety and there the one i need to get to, so i can get the spindle working again and the chuck clamp, all because the batteries dyed and all parameters lost
Old 04-27-2005, 07:06 PM
9566317 is on a distinguished road
If you lost everything because of the battieries you need to load the first 10 lines by hand then if you have your parameters downloaded you should be able to download them back into the machine.
You will have to enter the 900 parameters I think by hand,
Generaly you do not loose the laddes as it is a writen chip.
If it is faulty then you have a bigger problem as you will need to get the machine tool maker to burn you a new one.
If you are having problems getting any thing to work and you do have the parameters downloaded and saved you can always do the wipe everything clean by holding the i and p during power up
Be careful as this wipes the controler clean and if you do not have the parameters backed up you will own a large boat anchor.
"Be CAreful and think everything thru before pulling the plug"
[IMG] code is Off
Parameters No. for file transfer on a Fanuc O-mate controller Niall Fanuc 8 06-03-2009 08:14 AM
parameters for anca 2000 hercus compulathe poppyplant Machine Problems, Solutions , Wireless DNC, serial port 2 05-26-2005 11:26 PM
Need help with machining parameters tex G-Code Programing 4 03-02-2005 02:44 AM
Help with parameters on EG&G servomotors Baloo76 Servo Motors and Drives 6 12-09-2004 03:40 AM
Parameters on Cobra 42 Hardinge Niall Bridgeport and Hardinge Mills 0 07-16-2004 04:38 AM
