Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 10-07-2009, 09:40 PM
LCIIIA is on a distinguished road
motor tuning problems, I think
I purchased a first generation smithy CNC ready mill 12/40. The lead screw appears to be 6 TPI. Keling 1800 oz motors 1.8 degree x 3 and am using a Logitrol control and power system. MACH3 software and a windows PC 2.7 GHZ with XP which has a built in parallel port.
Problem When I set the machine to move 1" inch in X, Y, Z axis it will move .305". I have tried the MACH3 program which supposedly provides the correction. When I accept the correction a notice appears stating the kernal speed 25000 is not fast enough? How do I select the correct kernal speed for my computer? Or should I be tuning the motors differently?
Jim
Old 10-07-2009, 10:02 PM
pminmo's Avatar
pminmo is on a distinguished road
Jim
Config-Motor Tuning see attached
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 10-12-2009, 11:49 PM
thank you for the assistance, much appreciated
I finally have it tuned. Now time to make something.
take care
Jim
[IMG] code is Off
New Machine Build- Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR) MDF_Markazi Mach Software (ArtSoft software) 7 04-30-2009 02:15 AM
Servo Tuning Problems? RYANPB Gecko Drives 1 11-27-2008 12:43 PM
Motor tuning problems rodzilla Benchtop Machines 17 02-26-2008 07:16 AM
PID Tuning Problems ltoy Servo Motors and Drives 13 11-16-2007 11:43 AM
problems with tuning of Rutex drives FrankdB Servo Drives 2 06-21-2004 03:16 AM
