Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 07-01-2009, 03:41 AM
rai rai is offline
rai is on a distinguished road
Smile Fanuc OMC DNC
I have a VMC equipped with Fanuc OMC cnc, I am running on DNC this machine, although it is working but axis are in jerking movement (Commanded feed is 4000 but actual feed is 900 approx.) while axis are interpolating (Contouring). Even I had checked it's mechanical part but it's ok. I think cnc is reading nc file from pc but machine is not responding well. kindly help me out from this problem.
DNC parameters are as follows:
Baudrate 9600
Data bit 7
Stop bit 2
Parity even
handshaking software (Xon/off)
Is it a problem of handshaking?
or CNC system?
Please help me !!!!!!!!!!!!!!!!
Old 07-19-2009, 11:15 AM
gm3211 is on a distinguished road
Turn the feedrate down on the machine and see if that makes any changes...
Greg Mercurio -Shop Floor Automations
www.shopfloorautomations.com /619-461-4000
Old 07-30-2009, 09:21 AM
justtx is on a distinguished road
If you break your program up into small chunks to get it into the memory, you can test the programming of the program itself. Yes, it's going to require putting multiple chunks of the program into the memory, but you can prove out the DNC mode and speeds.
If that works, then you know you're not sending the program fast enough into the control while DNC'ing and the machine is starving for data...
Old 07-30-2009, 11:40 AM
inventcom is on a distinguished road
Fanuc OMC
rai,
for the Fanuc you should also check the cables, you can find the correct costruction on page 60 of the CNCnet DNC Operator manual (also applies to other DNC Software):
http://cncnetdnc.wieland.us/
Martin
Old 08-09-2009, 09:20 PM
If the machine is communicating, then it's not a cable issue. Just FYI...
The wiring of that cable could change from software to hardware flow control, if the control support it.
Old 08-10-2009, 03:00 PM
jimwymz is on a distinguished road
DNC issue
Baudrate 9600
Data bit 7
Stop bit 2
Parity even
or CNC system?
Hello Rai,
The varied responses indicate that you could have benefitted by adding some clarification (responses) to the guys who offered suggestions.
All of the folks who help, like to get some feedback, and it helps us to understand the problem better to help you and otherin the future!!
Please keep that in mind and asnwer my following questions.
If you already found a solution... Please post it so everyone can know it's closed and what the solution was!!
End of Pseudo Rant.....
Rai,
At the Baud rate you are using (9600) you may be starving the machine for Data.
I have some questions to ask you to clarify the problem, (for me and anyone else).
1. What is the Software you are using to send the DNC File to your CNC?
2. What is the wiring Pinout of your communications cable?
2b. How long is your communication Cable?
3. Does your Control have a PCMCIA card slot to one side of the CRT/LCD?
4. As asked earlier, can you load into memory a small part of your program and run it at the programmed feeds?
5. How large is the DNC Program?
6. Is it made up of Very Many lines with Very Small Moves (Less than 1 millimeter per axis?
7. Does your machine have the Option "G08 Look Ahead Control?
go to MDI Mode and enter G08 P1; input and press cycle start.
If you get an Alarm P/S 010 Improper g-code, then you do not have this option.
8. can you pm me with your e-mail address and Phone #?
thx
JimWymz
Old 05-07-2012, 07:21 AM
chandansingh is on a distinguished road
Originally Posted by jimwymz View Post
Hello Rai,
Rai,
thx
JimWymz
Hi dear
have u found the solution for feed or not ?
if yes please tell me. i have same problem
thanks
chandansingh0123@yahoo.com
Old 05-07-2012, 11:27 AM
rai rai is offline
Sorry.... Not yet
I think it is not possible in Fanuc OM-C
Originally Posted by chandansingh View Post
Hi dear
thanks
[IMG] code is Off
GE Fanuc & FANUC proprietary posts CNCadmin Fanuc 44 01-05-2012 08:54 AM
FANUC & GE FANUC Repairs RRL Product Announcements & Manufacturer News 1 04-17-2011 11:50 AM
Fanuc & GE Fanuc Repairs RRL Product Announcements & Manufacturer News 0 10-01-2008 12:42 PM
Need post UG NX post for Fanuc Robodrill with Fanuc Series 16i-MB shj066 Post Processor Files 2 07-12-2007 01:59 PM
