| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
I have a Mitsubishi Meldas 500 Control on a Mighty USA Condor bridge type VMC. Can anyone tell me how to adjust the spindle orientation? I know some machines are mechanically adjusted and others can be adjusted through a parameter setting. I have done this before on newer Mitsubishi Control, but this one is different. |
| After taking a close look at the spindle parameter page I discovered how to accomplish the spindle orientation adjustment on the Mitsubishi Meldas 520AMR Here's how it goes..... 1) Press DIAGN-IN/OUT key 2) Under DEVICE enter (1001) then right arrow over to MODE 3) Under MODE enter (M) 4) Press INPUT/CALC key. This puts you in manual mode 5) Press TOOL/PARAM key 6) Press MENU key until SPINDLE option appears 7) Press the key under SPINDLE to highlight it 8) Press the arrow key next to MENU to page down to page 6/40 9) Locate parameter 15 OPST (deg) and parameter 16 OINP (deg) Note: These two parameters control the position stop and the in position range in degrees of the spindle dogs. 10) To change values enter #(15) NO.<1> DATA(100). DATA is the new value Increase the number to rotate clockwise, decrease for CCW. 11) To change parameter 16 enter #(16) NO.<1> DATA(10). My machine is set to 10 and seems to work fine. 12) Before re-orienting the spindle with the new values remove the spindle cover to gain access to the magnetic positioning sensor. This is a small sensor pointing toward a flat shiny metal pad attached to the spindle shaft. 13) Disconnect the lead wire connected to the orientation module and wait approx. 1 minute, then reconnect it. This remembers the new values 14) Re-orient the spindle and you now have the new position. 15) Now set the parameters page back to user 16) Press DIAGN-IN/OUT key 17) Under DEVICE enter (1001) then right arrow over to MODE 18) Under MODE enter (U) 19) Press INPUT/CALC key. This puts you back in user mode SWEET!! |
| Tags |
| meldas 500, spindle orientation |
| Need Help!- Have no spindle orientation | plofkop | Okuma | 8 | 04-05-2010 03:47 AM |
| Need Help!- Spindle Orientation | JIMMY | General Metal Working Machines | 5 | 08-03-2008 11:15 AM |
| Spindle orientation | StampCraft | Haas Mills | 5 | 11-10-2007 05:31 PM |
| Spindle orientation | jimecv | Daewoo/Doosan | 4 | 11-09-2007 11:25 AM |
| 16i / 18i Spindle Orientation... | Sump Cleaner | Fanuc | 12 | 09-11-2007 07:46 AM |
