Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 02-06-2005, 11:11 PM
DHE DHE is offline
DHE is on a distinguished road
Unhappy Cincinatti T-10 B-axis
I Am setting up a Cincinatti T-10 I purchased used, and are trying to get it to run for the first time.I can get all the contouring axis (xyz) to align, but when I try to align the 360 degree index B-axis it raises up, rotates about 15 degrees, and then shuts down, thowing a B-axis servo error out. I have checked the servo motor, tachometer, wiring, all being OK.
If anyone has knowledge on this machine to help, it sure would be apreciated.
Dale : DHECR250@aol.com
[IMG] code is Off
4020 4th axis problems little bubba Fadal 3 06-13-2005 09:08 PM
No Encoder Counts On X Axis. Y=OK murphy625 CamSoft Products 5 03-08-2005 08:20 PM
2 axis to 3 axis conversion drembedded Bridgeport and Hardinge Mills 10 10-27-2004 11:32 AM
fourth axis indexer senor J. DIY-CNC Router Table Machines 1 08-04-2004 03:34 PM
My Lathe project; might CNC it one day Stevie General Metal Working Machines 86 06-21-2004 08:27 PM
