| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
Hi guy's! glad i found this place. it's a treasure trove of undiscovered proportions! I have a System i got from a sign co that couldn't get it to work. got it back to the shop and ripped out the hpgl controller, put a BOB on it, through a Computer together, and ran Mach 3. everything was perfect and i am like a proud new father until. i started messing around with photo vcarve. it seams that my Z (ball screw) is dropping in a liner fashion. in a program that was 166550 lines of up and down motion i set it up to be a max depth of 1.35mm. when it starts out everything is fine and looks like it's working great. however. it seams to drop steps on the up travel of the z. i end up at the end cutting in about 4 or so mm. i checked the driver board (IM804) and changed it out for the h of it. still the same thing. resolution does make a difference. i set the rez to 1/2 (lowest these drivers will go) and the drop was over an inch over about 200 passes! raised it up back to 1/256 and it's back to the 4mm. i am now thinking that the motor is messed up or something, as i ripped the z apart and found a slight play in the coupler from the motor to screw, repaired that and it still does the same thing. not sure if i'm explaining this correctly but will answer any questions asked to the best of my ability. thanks! |
| Knitehawk, Try slowing the feed rate down. P.S. More detail would help accurately diagnose the problem. 1:Feed Rate 2: Type of material being cut 3: Cutter size 4: Ballscrew tpi 5: Stepper motor torque specs 6: Power supply Welcome to the Zone, Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| tried slowing the feed rate. it just does the same thing slower 8-) motor is rapid syn 23d-6309a Static torque=150oz-in rated current 4.6A Voltage 2.2V Resistance per phase .48ohms Inductance per phase .90mH nema 23 heres the info i have on Mach right now. screw looks like 2.5mm per turn psu is a meanwell se-600-48 thats a 600W 48v PSU 10125.86931 steps per mm speeds are 596.7 mm per min 68.175117 acceleration .0069522 G's |
| Did you install the power supply or is it the original? Have you tried reducing the micro stepping? 10125.86931 steps per mm may be swapping the CPU, that is a gigantic amount of step pulses to process. Do you have a instant messenger? Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. Last edited by jalessi; 05-24-2009 at 02:46 PM. |
| I would reduce the microstepping by a large factor. 2.5 mm TPI screws would still give a .0127mm resolution at full stepping. Raising the current to 4.6 amps will also help. Your steppers make all there power at a very low r.p.m. I would also enable the Sherline mode in Mach3 See attached .jpg What CPU is in your computer? Jeff...
#10
| nailed it. turned out that i had an intermittent connection on one of the wires (get this) on the Y axis. apparently there was crosstalk to the z axis screwing up the signals. the wire was broken inside the damn insulation. (that was fun to find!) Thanks for all the help Jeff! just did a photocarve of the wife! Looked great! Wish i could post pics here. |
| Z Axis dropping | GM Barton | DIY-CNC Router Table Machines | 12 | 11-11-2008 07:21 PM |
| dropping tools need help | porkchop21 | Bridgeport and Hardinge Mills | 7 | 02-02-2007 10:28 AM |
| Full Steps -vs- Micro Steps | DJB282000 | General Electronics Discussion | 10 | 12-28-2005 11:25 PM |
| Voltage dropping Resistor? | dmgdesigns | General Electronics Discussion | 4 | 09-22-2004 10:32 PM |
