Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 05-06-2009, 09:40 AM
homchz is on a distinguished road
Fadal 4020 Not Aligning Cold Start
The machine has run fine for the last month we have had it (bought used). We set the cold start and home in the same position for ease of use.
Today the machine seems to want to find CS anywhere from .250 to .110 above the line. Any attempts to reset CS do not work, and I do not believe I have an easily adjustable resolver as the book shows. If I do turn the black top it will drop at least and inch at a time and throw me an error 18 or 23.
Maybe the resolver itself is bad.
Any thoughts??
[IMG] code is Off
FADAL VMC 4020 dmac88 Fadal 7 05-18-2009 02:45 PM
Fadal shuts down when cold? Edster Fadal 4 11-23-2007 01:52 AM
How do I tell the age of a FADAL 4020? Rickady Fadal 8 07-10-2007 06:02 AM
904-1 cold start yeepman2 Fadal 2 05-02-2006 08:58 AM
4020 fadal cant get past "Cold Start" chipsahoy Fadal 13 03-07-2006 06:29 PM
