Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 04-22-2009, 02:20 PM
joebro is on a distinguished road
dnc drip feed Allen Bradley 9/260
Hello,
I have just acquired a Motion Master 5 axis cnc router with Allen-Bradley 9/260 controller. Does anyone have any experience drip feeding via serial connection to this particular setup? I am hoping to cut some fairly complicated 3d contours using NX-6 CAM to generate the G-code. Any advice that you have regarding dnc software and communications protocols would be appreciated.
Thanks.
Old 08-03-2009, 12:43 PM
alexplace2001 is on a distinguished road
AB 9/260 G code download
Hi
You can download G code to the AB 9/260 controller using the ODS software. This software is MS-DOS based, and gives you the option to dowload the code.
This link describes the procedure:
http://racustomercare.custhelp.com/a...ail/a_id/25311
The ODS manual is in the next link:
http://literature.rockwellautomation...m051_-en-p.pdf
Hope this helps.
Alex
[IMG] code is Off
Allen-Bradley 160S VFD mikelow57 Phase Converters and VFD 3 01-12-2011 08:57 PM
Allen Bradley phil spanner Computers and Networking 0 06-15-2007 07:41 PM
Allen Bradley plc 500 phil spanner Computers and Networking 6 01-31-2007 11:16 PM
Allen Bradley 1771 macgeek10 General CNC (Mill and Lathe) Control Software (NC) 8 05-25-2006 03:59 PM
Allen Bradley Help for new guy kroberts Servo Motors and Drives 5 11-26-2005 10:08 PM
