Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 04-20-2009, 03:38 PM
flannman is on a distinguished road
Num servo drive - onder voltage
Hi All
I have a Pierce all cnc turret punch which has a fault on the y axis. It is an Num servo drive which has three lights lit when powered up which relates to an under voltage alarm however i have checked the voltage and it is around 420v. The unusual thing is that when the machine is in an emergency stop state the drive says its ok however there is no voltage to it. Any ideas would be great
[IMG] code is Off
Mitsubishi Servo Drive Voltage Mcyoda Servo Motors and Drives 2 03-12-2009 09:59 PM
Newbie- AC Servo voltage HuckMilton Servo Motors and Drives 16 11-25-2008 09:47 AM
High voltage & high power servo drive design Xerxes Granite Devices 32 08-22-2008 09:24 PM
Fanuc DC servo, what voltage? Jonne Fanuc 3 09-21-2007 09:27 AM
What dc voltage to use on rutex R90H drive BOB F Rutex Products 17 11-28-2005 10:22 AM
