Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Machine Problems, Solutions , Wireless DNC, serial port
Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here!
Old 04-20-2009, 03:29 PM
hotpuppy is on a distinguished road
line feed issues Predator to Hurco KMB1M
I'm trying to get dnc working between my pc and my Hurco KMB1M. I have the ATMS Inc. BX upgrade board. Currently using 9600bps/7/e/2 xon/off. Communication itself is fine.
Where I'm hitting a brick wall is with the cr/lf settings in predator (under bobcad). When I use ignore I get a high character (graphic character likea lambda and a sigma) before and after each line. These trip a error on the console of the Hurco. When I use "strip" I get a "long line" error for lines exceeding 128 characters. Using variations of these settings don't seem to work.
What is the right character to terminate the line with?
I am sure someone else is using bobcad to run their Hurco. I'd appreiate knowing what settings you use.
thanks,
-Brian
[IMG] code is Off
Problem- Line Noise (COM via Predator/RocketPort) SeanO Machine Problems, Solutions , Wireless DNC, serial port 7 04-26-2009 06:40 PM
Need Help!- drip feed issues brahn21 Fanuc 2 10-15-2008 01:44 PM
Hurco 5M Neeed feed Back Please. roadbyte General Metalwork Discussion 1 03-26-2007 08:55 PM
Hurco 5M Need feed Back Please roadbyte HURCO 0 03-25-2007 05:10 PM
