| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
CNCnet DNC integrates your CNC machine controls with serial (RS232) interface directly into your network and controls an unlimited number CNCs simultaneously on a single computer. Cabling can either be made by using a direct cable, a serial - network interface or a wireless module. No need for Computers or special terminals at the shopfloor area. All transmission activities can be controlled by the operator panel of the machine. Protocols included: ACIERA, DDCMP, Mazatrol CMT, MEFI/Trans, BPA/9, LSV2, PRN, 3964/3964R, Heidenhain, PTR-Simulator Supports various interfaces: real or virtual COM ports (USB, WLAN, device and COM Servers) Setup of machine specific transmission parameters (leading - trailing sequences / characters, change or replace characters, send specific HEX ASCII codes). Recharge (drip feed) operation mode for large programs (SW / HW handshake) Suitable for Microsoft Windows XP (x32-x64), Vista (x32-x64), Server 2003 (x32-x64), Server 2008 (x32-x64), Virtual PC 2004 – 2007, Virtual Server 2005 and Hyper V Server 2008 Pre-built machine specific setup files for more than 800 types of machines are available from Inventcom Integration of Pre- and Postprocessors for automatic NC file manipulation (Replace Characters, separate and modify NC files, format tool preset data). Register and Download(free): http://www.wieland.us/cnc-erp/en/ind...artikel=678806 Trial: http://sec.dnc.at?u=3071&u1=3775&f=CNCnet_DNC_en.msi To all who are having problems with DNC transmission: Detailed instructions on cabling and setup are also included - Preset files for more than 800 control types are available! |
Jul 09: Due to high demand for printable manuals for CNCnet DNC an online version for download is available now in Adobe PDF format: CNCnet DNC 8.4 Configuration / Operating Manual (PDF, 727kB) http://cncnetdnc.wieland.us/ |
1) A virtual serial port is an emulation of the standard serial port. This port is created by software which enable extra serial ports in an operating system without additional hardware installation (such as expansion cards, etc.). Unlike a physical serial port the virtual one can be assigned any name (COM255, VSP33, etc.). It is possible to create unlimited number of virtual serial ports in your PC. The only limitation is the computer performance, as it may require a substantial amount of resources to emulate large numbers of serial ports. http://en.wikipedia.org/wiki/Serial_port 2) We do also have a driver for IP based communication with external serial servers, no RS232 needed at all (see picture) See also manual page 22, manual can be downloaded here: http://cncnetdnc.wieland.us/ |
All, as there are lots of questions about cabling here I've added typical cable contruction examples that should fit to 99% of all CNC's. Be aware that there are some older control types (e.g. Heidenhain) that require straight, not crossover wiring as the SEND / RECEIVE and Handshake wires are already crossed over inside the control. This Wiring instructions are also applicable to other DNC software. Martin P.S.: Can also be found at the end of the operators manual (download): http://cncnetdnc.wieland.us/ |
| Free 3d Mechanical Cad Tool, Did anybody try the free 3D CAD too CoCreate is offerin | hansge31 | Mechanical Calculations/Engineering Design | 1 | 06-20-2007 02:13 PM |
| Free Doors--Free Cabinet Door Software | 1BigPig | General CNC (Mill and Lathe) Control Software (NC) | 1 | 06-07-2007 01:36 PM |
| Free 2d Cad | ger21 | General CAM Discussion | 0 | 09-23-2006 12:56 PM |
| Free CAM: cam.py | FritzX | General CAM Discussion | 12 | 02-24-2006 11:25 AM |
