| Machine Problems, Solutions , Wireless DNC, serial port Need help with your Machine or need a Machining solutions for , Serial Port, Cable problems between PC and all others DNC problems disucss them here! |
My Fadal VMC has an RS232 cable for sending programs or DNCing with. My new-to-me laptop has no serial port. What to do? I have USB, firewire and parallel. I have looked at PCMCIA to serial cards - this will definately work but is pricey. I have found USB to serial interfaces starting at $10 - will this work- maybe? Is there any such thing as a parallel to serial adapter that would work. Maybe there is someway to do wireless without an adapter at all (thinking receiver on the machine?) Give me the goods guys.
| I have used USB to RS232 on my Compaq with no problems. Al
| We do wireless DNC to our machines. We use Predator DNC (although any other should work, I assume) that communicates to our wireless access point via our network, then to the machines using a wireless Ethernet to serial device at the machine. On one of our machines we go up 19.2, but generally we stay at 9600 or 4800. The units are around $200-$300 (we have different modles purchased at different times of our implementation.) We got ours from www.mis-group.com and installed it ourselves (had some driver issues but that got worked out.) I don't know of any paralell to serial device. Hope that helps. |
| USB to RS-232 is definitely your most cost effective solution. No reason I can think of (based on your stated intentions) to consider anything else. Regards, Paul Sevin Ovation Engineering, Inc. http://www.ovationengineering.com
__________________ Paul Sevin - Ovation Engineering, Inc. http://www.ovationengineering.com |
| I have been using the WiBox from Lantronix. It seems to work fairly well and the setup is pretty simple. The cost is around the $325 range. If you go on their web site, you will find many different devices that are made for the Serial port industry. www.lantronix.com |
| I got a "Cables to go" USB to Serial today about $20CDN came with software. Also my new wireless will send to the back of my shop (yippee) albeit a little slow (1-2 Mps) now I can access the network for my files instead of transfering with USB mem stick. I will be trying this laptop on my Fadal today or tomorrow. I will post results on the use of this inexpensive device (USB-Serial).
| I have noticed no differences in the communication or control of my machine (as compared to what I was doing). I would recomend this method of adding a serial connection to anybody. In case you want to know the part is "Cables to go" USB to DB9 Serial Adapter #C184-26886
#12
| As stated above - I am running Win XP - obviously this adapter works. I use it to comm and DNC to my 94 Fadal as well as to comm with my 85 Sodick.
| VK45 serial port | TJ in CT | Mazak, Mitsubishi, Mazatrol | 16 | 11-07-2005 09:52 AM |
| pic chip SERIAL to step/dir and controll | berin | Open Source Controller Boards | 13 | 02-18-2005 05:23 PM |
| Serial or Parallel port drive | Max | General Electronics Discussion | 8 | 11-02-2004 12:20 AM |
| CAD/CAM Serial Control Software | AndG | General CAM Discussion | 2 | 05-10-2004 07:43 PM |
| Using A Laptop Without Serial Port | mtech | Computers and Networking | 6 | 08-17-2003 08:58 AM |
